[Geoserver-devel] [jira] Created: (GEOS-2281) LoggingFilter eats the input stream when dumping POST contents
                 Key: GEOS-2281
                 URL: http://jira.codehaus.org/browse/GEOS-2281
             Project: GeoServer
          Issue Type: Task
            Reporter: Andrea Aime
            Assignee: David Winslow
Hi David,
playing on trunk with POST logging enabled (and using the old UI) I noticed that the enabling POST dump in LoggingFilter actually eats the input stream the dispatcher should receive, with the result the request does not work at all.
Is this a bug that has been fixed on 1.7.x or on trunk under the new UI, or is this something new?
