Quickly configure many feature types/coverages
Key: GEOS-2287
URL: http://jira.codehaus.org/browse/GEOS-2287
Project: GeoServer
Issue Type: New Feature
Components: Configuration, Wicket UI
Affects Versions: 1.7.0-RC4
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 2.0.x
One of the most required features at FOSS4G 2008 was the ability to quickly configure many layers.
Whilst this can be done using the REST api, what people were looking for is a simple UI to do so:
* get a store that contains many layers
* cherry pick (or select all) the layers you want GeoServer to auto configure, eventually hint the srs they are in, eventually provide a default bbox, eventually provide a default style per type?
* have GeoServer go thru them and auto-configure those that it can figure out, report those that could not be configured (use the well known default styles depending on the nature of the data)
