[Geoserver-devel] [jira] Created: (GEOS-229) sdo_geom.gtype not set correctly when inserting features on Oracle (10g)
Message:
  A new issue has been created in JIRA.
View the issue:
  http://jira.codehaus.org/browse/GEOS-229
Here is an overview of the issue:
        Key: GEOS-229
    Summary: sdo_geom.gtype not set correctly when inserting features on Oracle (10g)
       Type: Bug
     Status: Open
   Priority: Major
Original Estimate: 1 hour
Time Spent: Unknown
  Remaining: 1 hour
    Project: GeoServer
Components:
             WFS
             Transactions/Locking
             Oracle
   Assignee: Sean Geoghegan
   Reporter: Thijs Brentjens
    Created: Thu, 14 Oct 2004 5:30 AM
    Updated: Thu, 14 Oct 2004 5:30 AM
Environment: Oracle 10g
Description:
When inserting features with the WFS on an Oracle database (10g), it seems that the SDO_GEOM.GTYPE is not set correctly. For example: for points the gtype is set 1 (or: 0001), for lines gtype is set 1002. So the first digit (the dimension) is not correct.
As far as I get it, this gtype-value is set with GeoTools, in org/SQLEncoderOracle.java. So maybe this is the place to report the issue, but hopefully someone can help out.
Anyway, I'm not a Java-developer, but my guess is that in SQLEncoderOracle.java the function [geometryType].getDimension(), e.g. used in SQLEncoderOracle.java as point.getDimension or line.getDimension(), doesn't return the correct value (that is '2'). I do not have a Java environment to develop/debug anything now, so hopefully somebody can solve this problem.
Thijs
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
