Allow multiple service instances per server
Key: GEOS-2291
URL: http://jira.codehaus.org/browse/GEOS-2291
Project: GeoServer
Issue Type: New Feature
Components: Configuration
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 2.0.x
Having just a single WMS/WFS/WCS per server is limiting, deploying multiple GeoServers into the same container consumes quite a bit of permgen memory and does not allow for easy sharing of data.
What we want is the ability of setting up multiple services, each with his own set of layers, but backed by a common catalog, within a single GeoServer instance. This is the idea of "maps" in the new UI/catalog work, where each map is a sort of virtual geoserver, with its own services and layers, each layer being backed by shared sets of feaure types and coverages in the catalog.
[ http://jira.codehaus.org/browse/GEOS-2291?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Ben Caradoc-Davies reopened GEOS-2291:
Andrea, I do not think this is complete. How do we configure a second service URL to serve multiple feature types in multiple namespaces? Surely this would require some sort of container to represent the new service URL that contains the multiple workspaces/namespaces? Where is this implemented in the catalog?
Key: GEOS-2291
Project: GeoServer
