See revision # in the UI on non-tagged builds
Key: GEOS-2324
URL: http://jira.codehaus.org/browse/GEOS-2324
Project: GeoServer
Issue Type: New Feature
Components: UI
Affects Versions: 2.0-alpha1, 1.7.0
Reporter: Mike Pumphrey
Assignee: Andrea Aime
Priority: Minor
Fix For: 1.7.x, 2.0.x
Since we often build GeoServer in between official releases, it would be nice to see a place in the UI where the SVN revision number is displayed. ("Built from r8675309") This way, one could distinguish two different GeoServer builds from the same branch (where the version numbers for both would be the same).
If there is a way to do this currently, I apologize for the unnecessary task.
