[Geoserver-devel] [jira] Created: (GEOS-2325) mvn install FAIL on latest trunk
                 Key: GEOS-2325
                 URL: http://jira.codehaus.org/browse/GEOS-2325
             Project: GeoServer
          Issue Type: Bug
            Reporter: Mathew Wyatt
            Assignee: Andrea Aime
When doing a mvn install on the latest trunk it fails because maven can't find the maven-assembly-plugin. The dependencies list was missing from the plugin.
I fixed this by changing the following:
<plugin>
                <artifactId>maven-assembly-plugin</artifactId>
                <version>2.1</version>
                <configuration>
                    <descriptors>
                        <descriptor>release/src.xml</descriptor>
                        <descriptor>release/war.xml</descriptor>
                        <descriptor>release/javadoc.xml</descriptor>
                        <descriptor>release/bin.xml</descriptor>
                        <descriptor>release/doc.xml</descriptor>
                        <descriptor>release/ext-db2.xml</descriptor>
                        <descriptor>release/ext-gml.xml</descriptor>
                        <descriptor>release/ext-mysql.xml</descriptor>
                        <descriptor>release/ext-oracle.xml</descriptor>
                        <descriptor>release/ext-vpf.xml</descriptor>
                        <descriptor>release/ext-arcsde.xml</descriptor>
                        <descriptor>release/ext-pyramid.xml</descriptor>
                        <descriptor>release/ext-wfsv.xml</descriptor>
                        <descriptor>release/ext-gwc.xml</descriptor>
                        <descriptor>release/ext-gdal.xml</descriptor>
                        <descriptor>release/ext-h2.xml</descriptor>
                    </descriptors>
                    <finalName>geoserver-2.0-SNAPSHOT</finalName>
                    <outputDirectory>${project.build.directory}/release</outputDirectory>
                </configuration>
            </plugin>
to
<plugin>
                <configuration>
                    <descriptors>
                    </descriptors>
                </configuration>
                <dependencies>
                    <dependency>
                        <groupId>org.apache.maven.plugins</groupId>
                    </dependency>
                </dependencies>
            </plugin>
