[Geoserver-devel] [jira] Created: (GEOS-2326) incorrect sql statement
                 Key: GEOS-2326
                 URL: http://jira.codehaus.org/browse/GEOS-2326
             Project: GeoServer
          Issue Type: Bug
          Components: PostGIS
    Affects Versions: 1.7.0 , 1.6.5
         Environment: suse sles 10
            Reporter: Uli Rothstein
            Assignee: Andrea Aime
sending the filter-condition
<ogc:Filter>
<And>
<ogc:PropertyIsLike wildCard='*' singleChar='.' escape='!'>
  <ogc:PropertyName>ud_id</ogc:PropertyName>
    <ogc:Literal>*888888888888</ogc:Literal>
  </ogc:PropertyIsLike>
  <ogc:PropertyIsEqualTo>
    <ogc:PropertyName>objekttyp_id</ogc:PropertyName><ogc:Literal>2</ogc:Literal>
  </ogc:PropertyIsEqualTo>
</And>
</ogc:Filter>
via get-parameter to geoserver versions 1.6.5 and 1.7.0.
Both versions build the sql statement:
28 Okt 08:18:00 DEBUG [data.jdbc] - About to execute query:
SELECT "object_id", "ud_id", "meldevertreter_id", "objekttyp_id", "bemerkung", "flaeche", "datum",
encode(asBinary(force_2d("the_geom"),'XDR'),'base64'), "objekttyp_name" FROM "gis"."f_lw_digi_flaechen"
WHERE ( ( "ud_id" LIKE '%999999999999' ) AND 'objekttyp_id' = '1') LIMIT 1000000
The attribute-name objekttype_id is single quoted but has to be double quoted.
