RESTConfig: Provide means of autoconfiguring pre-existing layers
Key: GEOS-2379
URL: http://jira.codehaus.org/browse/GEOS-2379
Project: GeoServer
Issue Type: Bug
Components: Configuration
Reporter: David Winslow
Assignee: David Winslow
In RESTConfig, there is already a mechanism for autoconfiguring a shapefile, but it requires uploading a zip file with the shapefile and friends. We should allow autoconfiguration of layers that are already present on the server (for example, you just added a PostGIS database with 100 tables. You want to expose them all with reasonable settings and don't care about handcrafting the metadata. RESTConfig should help with this.)
I'm adding an endpoint at rest/folders/{folder}/layers/{layer}/default[.{type}] that only supports GET requests. It returns the default configuration for the specified layer, complete with autodetected values for relevant fields (title based on store name, bbox based on data, etc.)
