[Geoserver-devel] [jira] Created: (GEOS-2405) NPE when saving catalog
                 Key: GEOS-2405
                 URL: http://jira.codehaus.org/browse/GEOS-2405
             Project: GeoServer
          Issue Type: New Feature
          Components: Configuration
    Affects Versions: 1.7.0
            Reporter: Andrea Aime
            Assignee: Andrea Aime
            Priority: Critical
             Fix For: 1.7.1
A user reported the following exception when trying to save the catalog:
{code}
java.lang.NullPointerException
  at org.vfny.geoserver.global.FeatureTypeInfo.getSrsHandling(FeatureTypeInfo.java:1742)
  at org.vfny.geoserver.global.FeatureTypeInfo.toDTO(FeatureTypeInfo.java:523)
  at org.vfny.geoserver.global.Data.toDTO(Data.java:1593)
  at org.vfny.geoserver.action.SaveXMLAction.saveGeoserver(SaveXMLAction.java:63)
  at org.vfny.geoserver.action.SaveXMLAction.execute(SaveXMLAction.java:45)
  at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
  at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
  at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
  at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
  at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
  at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
  at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
  at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
  at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
  at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
  at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
  at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
  at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
  at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
  at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
  at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
  at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
  at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
  at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
  at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
  at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
  at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
  at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
  at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:874)
  at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
  at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
  at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
  at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
  at java.lang.Thread.run(Thread.java:595)
{code}
I believe the reason for that is the most of the code playing with projection policy cannot handle null values, and that ProjectPolicy.get(int)
returns null in case the code is not found:
{code}
public static ProjectionPolicy get( Integer code ) {
        for ( ProjectionPolicy p : ProjectionPolicy.values() ) {
            if ( code.equals( p.getCode() ) ) {
                return p;
        return null;
{code}
Now, the convention was that if you don't know about the projection policy, the the policy is FORCE_DECLARED.
There is actually code around trying to enforce that, for example in the legacy catalog importer we see:
{code}
ProjectionPolicy pp = ProjectionPolicy.get( ftInfoReader.srsHandling() );
        if ( pp == null ) {
            pp = ProjectionPolicy.FORCE_DECLARED;
{code}
but that is not consistently used everywhere.
I would suggest that ProjectionPolicy.get(code) returns FORCE_DECLARED in all cases in which the code cannot be matched (and that we declare so explicity in the code).
