[Geoserver-devel] [jira] Created: (GEOS-2476) Filters are not added to the GetFeatureInfo request in the standard GeoServer map preview
                 Key: GEOS-2476
                 URL: http://jira.codehaus.org/browse/GEOS-2476
             Project: GeoServer
          Issue Type: Bug
          Components: UI
    Affects Versions: 1.7.0
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 1.7.2
Add a filter in the UI, refresh, the map gets updated, some elements disappear, but when clickling on the filtered out features, you still get back a response.
(try with states and CQL_FILTER -> PERSONS > 10000000).
Adding the CQL_FILTER=PERSONS>1000000 directly in the URL shows GetFeatureInfo works if the filter is properly set.
