[Geoserver-devel] [jira] Created: (GEOS-2485) WFS 1.0 transaction response contains spurious InsertResult element
                 Key: GEOS-2485
                 URL: http://jira.codehaus.org/browse/GEOS-2485
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
    Affects Versions: 1.7.1
            Reporter: Andrea Aime
            Assignee: Justin Deoliveira
             Fix For: 1.7.2
The transaction response to an operation that does not contain inserts looks like:
{code:xml}
<wfs:WFS_TransactionResponse version="1.0.0" ... >
  <wfs:InsertResult>
    <ogc:FeatureId fid="none" />
  </wfs:InsertResult>
  <wfs:TransactionResult>
    <wfs:Status>
      <wfs:SUCCESS />
    </wfs:Status>
  </wfs:TransactionResult>
</wfs:WFS_TransactionResponse>
{code}
While schema compliant, the presence of InsertResults there does not make sense. The schema does not require an InsertResult element to be present, the specification just says:
"The <InsertResult> element contains one or more feature identifiers of newly created feature instances. One <InsertResult> element is reported per <Insert> element in the request."
Which could be read as zero InsertResult elements for zero Insert elements. Besides nitpick details, having the InsertResult element is confusing and fid="none" is a valid fid as any.
