Geometry attributes fail to be recognized if the postgis metadata tables cannot be accessed
Key: GEOS-2499
URL: http://jira.codehaus.org/browse/GEOS-2499
Project: GeoServer
Issue Type: Bug
Components: PostGIS
Affects Versions: 1.7.1, 1.6.5
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 1.7.2
The followin stack trace:
{code}
2008-11-30 15:48:19,749 WARN [geoserver.filters] - Setting mimetype after acquiring stream! was:text/html;charset=UTF-8; set to: text/html; url was: http://map4change.org:8080/geoserver/config/data/typeEditorSubmit.do
2008-11-30 15:48:27,507 WARN [data.jdbc] - Error building attribute type. The column will be ignored
org.geotools.data.DataSourceException: ERROR: permission denied for relation spatial_ref_sys
at org.geotools.data.postgis.referencing.PostgisAuthorityFactory.createCRS(PostgisAuthorityFactory.java:97)
at org.geotools.data.postgis.PostgisDataStore.getGeometryAttribute(PostgisDataStore.java:1144)
at org.geotools.data.postgis.PostgisDataStore.buildAttributeType(PostgisDataStore.java:1001)
at org.geotools.data.jdbc.JDBC1DataStore.buildSchema(JDBC1DataStore.java:1183)
at org.geotools.data.postgis.PostgisDataStore.buildSchema(PostgisDataStore.java:678)
at org.geotools.data.jdbc.FeatureTypeHandler.getFeatureTypeInfo(FeatureTypeHandler.java:197)
at org.geotools.data.jdbc.FeatureTypeHandler.getSchema(FeatureTypeHandler.java:165)
at org.geotools.data.jdbc.JDBC1DataStore.getSchema(JDBC1DataStore.java:320)
at org.geotools.data.postgis.PostgisDataStore.getSchema(PostgisDataStore.java:1966)
at org.vfny.geoserver.form.data.TypesEditorForm.reset(TypesEditorForm.java:296)
{code}
Occurs when people store data in a namespace other than public and use a user that does not
have privileges to access the postgis metadata tables located in "public".
Fixes... hum, first of all we have to check that the postgis metadata tables really _have_ to
be located in public (seems a fair assumption since the geometry_colums table
has a schema column, if it was supposed to have of these per schema you probably
would not need it).
And then since we already have the srid, it's probably a good idea to just
decode EPSG:srid in case the table access fails.
