Running the service wrapper
Key: GEOS-2522
URL: http://jira.codehaus.org/browse/GEOS-2522
Project: GeoServer
Issue Type: Bug
Components: Configuration
Affects Versions: 1.7.1
Environment: Windows Server
Reporter: Carey Stranhaan
Assignee: Andrea Aime
Priority: Minor
Attachments: wrapper.log, wrapper2.conf
The service wrapper works fine in the previous version I had installed (1.6.4). When I upgraded to 1.7.1, I tried to reinstall the service wrapper, and Geoserver doesn't run. The problem seems to show up in the 8th line of the wrapper log where it says:
547 [WrapperSimpleAppMain] ERROR org.mortbay.log - failed org.mortbay.jetty.webapp.WebAppContext@anonymised.com{/geoserver,file:/D:/Program%20Files/GeoServer%201.7.1/webapps/geoserver/}
I have also attached my wrapper configuration file (wrapper2.conf).
Thanks for your help on this. Geoserver rocks!
