[Geoserver-devel] [jira] Created: (GEOS-2523) Paragraph sign character from ISO-8859-1 PostGis DB problem
                 Key: GEOS-2523
                 URL: http://jira.codehaus.org/browse/GEOS-2523
             Project: GeoServer
          Issue Type: Bug
          Components: PostGIS, WFS
    Affects Versions: 1.7.1
         Environment: GeoServer 1.7.1 on Windows 2000 Server 32bit
            Reporter: Jonas Beck
            Assignee: Andrea Aime
Having a paragraph or section sign '§' in a iso-8859-1 PostGis table and querying the data per WFS results in the following error and chopped geoserver output from the problematic char on. I can only receive the result XML up to the § char. Changing GeoServer charset from UTF-8 to ISO-8859-1 doesnt help.
Request: getFeature
        handle = null
        service = WFS
        version = 1.1.0
        baseUrl = http://srv-arc2:8080/geoserver/
        providedVersion = 1.1.0
        query = [net.opengis.wfs.impl.QueryTypeImpl@anonymised.com (group: null, propertyName: null, function: null, filter: null, sortBy: null, featureVersion: null, handle: null, srsName: null, typeName: [{http://www.openplans.org/topp\}Projekte])]
        maxFeatures = null
        outputFormat = text/xml; subtype=gml/3.1.1
        resultType = results
        traverseXlinkDepth = null
        traverseXlinkExpiry = null
        formatOptions = {}
16 Dez 14:12:32 WARN [geotools.xml] - org.geotools.data.crs.ReprojectFeatureResults@anonymised.com (org.geotools.data.crs.ReprojectFeatureResults) is not of type [Lorg.opengis.feature.simple.SimpleFeature;
16 Dez 14:12:33 ERROR [geoserver.ows] -
java.io.IOException
        at org.geotools.xml.Encoder.encode(Encoder.java:555)
        at org.geoserver.wfs.xml.GML3OutputFormat.write(GML3OutputFormat.java:123)
        at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:137)
        at org.geoserver.ows.Dispatcher.response(Dispatcher.java:711)
        at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:215)
        at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
        at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
        at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
        at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
        at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
        at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
        at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
        at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
        at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
        at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
        at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
        at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
        at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
        at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
        at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
        at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
        at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
        at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
        at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
        at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
        at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
        at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
        at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
        at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
        at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
        at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:206)
        at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:114)
        at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
        at org.mortbay.jetty.Server.handle(Server.java:324)
        at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
        at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
        at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
        at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
        at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
        at org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEndPoint.java:395)
        at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.io.IOException: The character '§' is an invalid XML character
        at org.apache.xml.serialize.BaseMarkupSerializer.characters(Unknown Source)
        at org.geotools.xml.Encoder.start(Encoder.java:1043)
        at org.geotools.xml.Encoder.encode(Encoder.java:868)
        at org.geotools.xml.Encoder.encode(Encoder.java:547)
        ... 53 more
        at org.apache.xml.serialize.BaseMarkupSerializer.fatalError(Unknown Source)
        at org.apache.xml.serialize.BaseMarkupSerializer.surrogates(Unknown Source)
        at org.apache.xml.serialize.XMLSerializer.printText(Unknown Source)
        ... 57 more
16 Dez 14:12:33 INFO [geoserver.ows] - Problem writing exception information back to calling client:
