KML / GeoTools bombs out on requests for bbox 90.00, 180.00 and so forth
Key: GEOS-2533
URL: http://jira.codehaus.org/browse/GEOS-2533
Project: GeoServer
Issue Type: Bug
Components: Google Earth KML Output
Affects Versions: 1.7.1
Reporter: Arne Kepp
Assignee: Arne Kepp
Fix For: 1.7.2
Ruins regionating for big datasets
2008-12-19 13:29:12,564 ERROR [kml.KMZHelper] - Empty tile, error message: MimeType mismatch, expected application/vnd.google-earth.kml+xml but got application/vnd.ogc.se_xml;charset=UTF-8 from http://localhost:808
0/geosearch/wms?format_options=regionateby:auto&layers=massgis%3AMORIS_CONMAPSG_POLY&width=256&styles=massgis_polygon&srs=EPSG%3A4326&format=application%2Fvnd.google-earth.kml%2Bxml&tiled=FALSE&version=1.1.0&except
ions=application%2Fvnd.ogc.se_inimage&height=256&bbox=90.0%2C-90.0%2C180.0%2C0.0&request=GetMap&service=WMS&transparent=TRUE
null
2008-12-19 13:29:13,099 ERROR [geoserver.geosearch] - Error occurred while pre-processing regionated features
org.geotools.referencing.operation.projection.ProjectionException: Latitude 90°00.0'S is too close to a pole.
at org.geotools.referencing.operation.projection.LambertConformal.transformNormalized(LambertConformal.java:222)
at org.geotools.referencing.operation.projection.MapProjection.transform(MapProjection.java:816)
at org.geotools.referencing.operation.projection.MapProjection.transform(MapProjection.java:855)
at org.geotools.referencing.operation.transform.AbstractMathTransform.transform(AbstractMathTransform.java:235)
at org.geotools.referencing.operation.transform.ConcatenatedTransformDirect.transform(ConcatenatedTransformDirect.java:68)
at org.geotools.referencing.CRS.transform(CRS.java:1131)
at org.geotools.referencing.CRS.transform(CRS.java:1197)
at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:557)
at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:512)
at org.vfny.geoserver.wms.responses.map.kml.NativeSortRegionatingStrategy.getSortedFeatures(NativeSortRegionatingStrategy.java:84)
at org.vfny.geoserver.wms.responses.map.kml.CachedHierarchyRegionatingStrategy.computeFids(CachedHierarchyRegionatingStrategy.java:352)
at org.vfny.geoserver.wms.responses.map.kml.CachedHierarchyRegionatingStrategy.readFeaturesForTile(CachedHierarchyRegionatingStrategy.java:284)
at org.vfny.geoserver.wms.responses.map.kml.CachedHierarchyRegionatingStrategy.getUpwardFids(CachedHierarchyRegionatingStrategy.java:427)
at org.vfny.geoserver.wms.responses.map.kml.CachedHierarchyRegionatingStrategy.computeFids(CachedHierarchyRegionatingStrategy.java:346)
at org.vfny.geoserver.wms.responses.map.kml.CachedHierarchyRegionatingStrategy.getFeaturesForTile(CachedHierarchyRegionatingStrategy.java:248)
at org.vfny.geoserver.wms.responses.map.kml.CachedHierarchyRegionatingStrategy.getFilter(CachedHierarchyRegionatingStrategy.java:163)
at org.vfny.geoserver.wms.responses.map.kml.KMLUtils.loadFeatureCollection(KMLUtils.java:499)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:169)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:133)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:123)
at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:560)
at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:711)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:215)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:47)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Thread.java:619)
2008-12-19 13:29:13,100 ERROR [geoserver.ows] -
java.io.IOException
at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:126)
