A misconfigured datastore prevents whole WFS to work
Key: GEOS-2540
URL: http://jira.codehaus.org/browse/GEOS-2540
Project: GeoServer
Issue Type: Bug
Components: WFS
Affects Versions: 1.7.1
Reporter: Andrea Aime
Assignee: Justin Deoliveira
Fix For: 1.7.2
Say datastore "pgng" cannot be configured because of a lack of a plugin (in particular, this is the postgisg-ng one, that I forgot to add into the GeoServer libs), and you're trying to access a layer by WFS that is served by another, working, datastore. GetFeature will fail anyways with the following error:
{code}
31 dic 11:11:44 ERROR [geoserver.ows] -
java.lang.RuntimeException: java.io.IOException
at org.geoserver.wfs.xml.v1_1_0.WFSConfiguration.configureContext(WFSConfiguration.java:182)
at org.geotools.xml.Configuration.setupContext(Configuration.java:558)
at org.geotools.xml.Encoder.<init>(Encoder.java:225)
at org.geoserver.wfs.xml.GML3OutputFormat.write(GML3OutputFormat.java:88)
at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:137)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:711)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:215)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:487)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1093)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1084)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:360)
at org.mortbay.jetty.security.SecurityHandler.handle(SecurityHandler.java:216)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:181)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:726)
at org.mortbay.jetty.webapp.WebAppContext.handle(WebAppContext.java:405)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:152)
at org.mortbay.jetty.Server.handle(Server.java:324)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:505)
at org.mortbay.jetty.HttpConnection$RequestHandler.headerComplete(HttpConnection.java:828)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:514)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:211)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:380)
at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:228)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:450)
Caused by: java.io.IOException
at org.vfny.geoserver.global.FeatureTypeInfo.getFeatureType(FeatureTypeInfo.java:1274)
at org.geoserver.wfs.xml.v1_1_0.WFSConfiguration.configureContext(WFSConfiguration.java:177)
... 53 more
at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:170)
at org.geoserver.catalog.ResourcePool.getFeatureType(ResourcePool.java:204)
at org.geoserver.catalog.impl.FeatureTypeInfoImpl.getFeatureType(FeatureTypeInfoImpl.java:71)
at org.vfny.geoserver.global.FeatureTypeInfo.getFeatureType(FeatureTypeInfo.java:1271)
... 54 more
Caused by: java.lang.NullPointerException: Could not aquire datastore 'pgng'
at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:159)
... 57 more
{code}
The schema cache configuration should be more tolerant.
Also, this error is kind of peculiar because it's triggered by a datastore lacking its plugin jars, but what about a ds that cannot be reached instead? Would it trigger a similar error?
