[Geoserver-devel] [jira] Created: (GEOS-2545) ResourcePool uses significant resources building renaming datastores
                 Key: GEOS-2545
                 URL: http://jira.codehaus.org/browse/GEOS-2545
             Project: GeoServer
          Issue Type: Bug
          Components: Global
    Affects Versions: 1.7.1, 1.7.0
            Reporter: Andrea Aime
            Assignee: Justin Deoliveira
             Fix For: 1.7.2
During benchmarks I noticed how renaming a feature type incurs in quite an overhead. Looking into it I discovered that a new RetypeingDataStore is created each time the renamed feature source is created. Due to the way the renaming datastore works, it requires to gather the full list of all type names from the original data store so that a getFeatureSource(name) request can be answered (the name transformation goes one way only, it's not meant to be necessarily invertible). When the wrapped datastore is postgis, this may require a lot of time (proportional to the number of layers available in the datastore).
It would be better to cache the renaming datastore as we cache the original ones. The alternative would require changing the retyping datastore so that it can do reverse name transformations... which I can do, thought it may not be trivial (and I would have to check the CITE tests pass on a fully renamed configuration).
Opinions? (btw, assigned to you just for the sake of discussion, I'll take it back when we have a decision)
     [ http://jira.codehaus.org/browse/GEOS-2545?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Andrea Aime reopened GEOS-2545:
Yeah, confirmed. Bruce, please provide a patch, there are not enough developers doing and way too many users asking
                Key: GEOS-2545
            Project: GeoServer
         Issue Type: Bug
         Components: Global
   Affects Versions: 1.7.0 , 1.7.1
           Assignee: Andrea Aime
            Fix For: 2.0.3
