NullPointerException on ReverseProxyFilter if running on the embedded Jetty
Key: GEOS-2547
URL: http://jira.codehaus.org/browse/GEOS-2547
Project: GeoServer
Issue Type: Bug
Components: Configuration
Affects Versions: 1.7.1
Reporter: Gabriel Roldán
Assignee: Gabriel Roldán
Fix For: 1.7.2
When using the reverse proxy filter, it may happen that {{ServletResponse.getOutputStream()}} is called before {{ServletResponse.setContentType}}. Since the filter depends on the set content type to determine whether to perform URL translation for the {{proxyBaseUrl}} on the response content, this is causing a
{code}
ava.lang.NullPointerException
at org.geoserver.filters.ReverseProxyFilter$CacheingResponseWrapper.getCachedContent(ReverseProxyFilter.java:315)
{code}
A solution being overriding getOutputStream with one that waits until the first write to determine whether to cache or not, based on the set response content type.
