[Geoserver-devel] [jira] Created: (GEOS-2555) changing FeatureType schema exceptions
                 Key: GEOS-2555
                 URL: http://jira.codehaus.org/browse/GEOS-2555
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 1.7.1
         Environment: GeoServer 1.7.1 installed on tomcat 5.5.23 using the war file
            Reporter: Michael Adair
            Assignee: Andrea Aime
getting a Class cast exception in Editor.jsp.
To reproduce the error, go to FeatureType editor (any feature type will do it seems, but I tested with tasmania cities), change the schema to the gml:abstractFeatureType, then try to add in the attributes, I get a JSP exception as follows:
javax.servlet.ServletException: ServletException in '/WEB-INF/pages/data/featureTypes/Editor.jsp': Getter for property attributeNames threw exception: java.lang.ClassCastException: org.vfny.geoserver.form.data.AttributeForm cannot be cast to org.vfny.geoserver.form.data.AttributeDisplay
  org.apache.jasper.runtime.PageContextImpl.doHandlePageException(PageContextImpl.java:846)
  org.apache.jasper.runtime.PageContextImpl.handlePageException(PageContextImpl.java:779)
  org.apache.jsp.WEB_002dINF.pages.layouts.mainLayout_jsp._jspService(mainLayout_jsp.java:652)
  org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:98)
  javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
  org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:328)
  org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:315)
  org.apache.jasper.servlet.JspServlet.service(JspServlet.java:265)
  org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.doForward(MultipleDelegatingTilesRequestProcessor.java:346)
  org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.processTilesDefinition(MultipleDelegatingTilesRequestProcessor.java:212)
  org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.processForwardConfig(MultipleDelegatingTilesRequestProcessor.java:81)
  org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:241)
  org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
  org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
  javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
  org.apache.struts.action.RequestProcessor.processForwardConfig(RequestProcessor.java:398)
  org.apache.struts.tiles.TilesRequestProcessor.processForwardConfig(TilesRequestProcessor.java:318)
  org.vfny.geoserver.config.web.tiles.MultipleDelegatingTilesRequestProcessor.processForwardConfig(MultipleDelegatingTilesRequestProcessor.java:95)
  org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
  org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
  org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
  org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
  org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
  org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
  org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
  org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
  org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
  org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
  org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
  org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
  org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
  org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
  org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
  org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
  org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
root cause
javax.servlet.jsp.JspException: ServletException in '/WEB-INF/pages/data/featureTypes/Editor.jsp': Getter for property attributeNames threw exception: java.lang.ClassCastException: org.vfny.geoserver.form.data.AttributeForm cannot be cast to org.vfny.geoserver.form.data.AttributeDisplay
  org.apache.struts.taglib.tiles.InsertTag$InsertHandler.doEndTag(InsertTag.java:923)
  org.apache.struts.taglib.tiles.InsertTag.doEndTag(InsertTag.java:462)
  org.apache.jsp.WEB_002dINF.pages.layouts.mainLayout_jsp._jspx_meth_tiles_005finsert_005f7(mainLayout_jsp.java:1368)
  org.apache.jsp.WEB_002dINF.pages.layouts.mainLayout_jsp._jspService(mainLayout_jsp.java:624)
