[Geoserver-devel] [jira] Created: (GEOS-2559) Re: GEOS2028 does does not seem to be fixed in 1.7.1
                 Key: GEOS-2559
                 URL: http://jira.codehaus.org/browse/GEOS-2559
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
    Affects Versions: 1.7.1
         Environment: WinXP
            Reporter: webb
            Assignee: Andrea Aime
         Attachments: Edit_ward_DescribeFeatureType.xml, wfsGetCapabilities.xml
We are still struggling with GEOS 2028(KVP parser uses Filter 1.0 parser configuration instead of 1.1)
We are using GeoServer 1.7.1
Request:
http://localhost:8080/geoserver/wfs?request=GetFeature&version=1.1.0&service=wfs&Typename=topp:EDIT_WARD&Filter=&lt;ogc:Filter xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:gml="http://www.opengis.net/gml&quot;&gt;&lt;ogc:Intersects&gt;&lt;ogc:PropertyName&gt;GEOM&lt;/ogc:PropertyName&gt;&lt;gml:Polygon srsName="26917"><gml:exterior><gml:LinearRing><gml:PosList>538841.491598445,4823912.03117224 538841.491598445,4824944.18868228 539215.312358337,4824944.18868228 539215.312358337,4823912.03117224 538841.491598445,4823912.03117224</gml:PosList></gml:LinearRing></gml:exterior></gml:Polygon></ogc:Intersects></ogc:Filter>
Reponse:
<ows:ExceptionReport version="1.0.0"
  xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd&quot;
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot;
  xmlns:ows="http://www.opengis.net/ows&quot; xmlns:xml="http://www.w3.org/XML/1998/namespace&quot;&gt;
  <ows:Exception
    exceptionCode="XML getFeature request SAX parsing error" locator="org.vfny.geoserver.util.requests.readers.XmlRequestReader">
    <ows:ExceptionText>org.xml.sax.SAXException: Attempted to construct illegal filter - I dont understand the tag: gml:exterior. HINT: tags are case-sensitive!
Attempted to construct illegal filter - I dont understand the tag: gml:exterior. HINT: tags are case-sensitive!</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
I am attaching the WFS GetCapabilities XML and the DescribeFeatureType for the layer used in the query, which supports gml:exterior.
Please can we know if the fixes mentioned in GEOS 2028 have been made?
