Push the IOUtils test utility class into the main source code and share directory and zip handling into it
Key: GEOS-2563
URL: http://jira.codehaus.org/browse/GEOS-2563
Project: GeoServer
Issue Type: Improvement
Components: Global
Affects Versions: 1.7.1
Reporter: Andrea Aime
Assignee: Andrea Aime
Fix For: 1.7.2
The OGR output format shares some requirements with the ShapeZIPOutput format and the test setup, in particular, temp directory creation, directory recursive deletion, and directory recursive zip operations. Does not make sense to duplicate them, better move IOUtils from the test code into the main code and share there the missing pieces (the zip related ones)
