[Geoserver-devel] [jira] Created: (GEOS-2591) startup.bat in -bin distribution won't work if JAVA_HOME is not specified
                 Key: GEOS-2591
                 URL: http://jira.codehaus.org/browse/GEOS-2591
             Project: GeoServer
          Issue Type: Improvement
          Components: Global
    Affects Versions: 1.7.2
            Reporter: Andrea Aime
            Assignee: Andrea Aime
             Fix For: 1.7.3
The .bat sets the wrong variable in that case. Also emit a warning that the "java" got from the current path should be a JDK one, otherwise javac won't be available and jsp compilation will go bye bye
