[Geoserver-devel] [jira] Created: (GEOS-2592) startup.sh doesn't bother to check PATH for java
                 Key: GEOS-2592
                 URL: http://jira.codehaus.org/browse/GEOS-2592
             Project: GeoServer
          Issue Type: Improvement
          Components: Configuration
    Affects Versions: 1.7.2
         Environment: UNIX
            Reporter: Paul Ramsey
            Assignee: Andrea Aime
            Priority: Minor
             Fix For: 1.7.3
         Attachments: geoserver-startup.patch
startup/shutdown.sh both just check for JAVA_HOME. In OS/X in particular, the concept of a particular JAVA_HOME directory doesn't exist, which could be confusing to folks. However, 'java' is just sitting there on the path, so we can test for that first.
