[Geoserver-devel] [jira] Created: (GEOS-2609) Geometry sort / regionating
                 Key: GEOS-2609
                 URL: http://jira.codehaus.org/browse/GEOS-2609
             Project: GeoServer
          Issue Type: Bug
    Affects Versions: 1.7.2
            Reporter: Arne Kepp
            Assignee: David Winslow
            Priority: Minor
             Fix For: 1.7.3
If you select regionating strategy: geometry
But then select a regionating attribute that is not a geometry, the form will let you do so, and the code fails with a class cast exception in
getSortAttributeValue(SimpleFeature f) , line 74, in GeometryRegionatinStrategy.
Can we have the UI fail if the attribute is not a geometry, the same way it fails if you do not have a bounding box set ?
Feel free to assign back to me if you have more important stuff.
