[Geoserver-devel] [jira] Created: (GEOS-2610) A True Type Font Symbol is flipped horizontally when using with a PolygonSymbolizer
                 Key: GEOS-2610
                 URL: http://jira.codehaus.org/browse/GEOS-2610
             Project: GeoServer
          Issue Type: Bug
          Components: Global
    Affects Versions: 1.7.2
         Environment: Windows XP, Geoserver 1.7.2
            Reporter: Tim Martin
            Assignee: Andrea Aime
Hi
I emailed the Nabble board today at 4:41pm to show my issue with a true type font symbol. It flips horizontally when called from the SLD.
I have tested by creating a flipped version of the TFF library and these symbols worked.
I am unsure if its because i am using the symbol attached to a Polygon Symbolizer or this problem applies to all.
Your example on the blog using Windings didnt seem to have the issue.
I have put this as a Major priority but not sure if it warrants that status.
many thanks
Tim
