[Geoserver-devel] [jira] Created: (GEOS-2624) ODF Toolkit
ODF Toolkit
                 Key: GEOS-2624
                 URL: http://jira.codehaus.org/browse/GEOS-2624
             Project: GeoServer
          Issue Type: Improvement
            Reporter: Arne Kepp
            Priority: Minor
             Fix For: 2.0.x
http://odftoolkit.org
We may want to give the ODF Toolkit a look for reporting needs. It can be used to justify renaming the Excel module to the Spreadsheet module (personal pet peeve), or to automatically generate reports / letters.
From past experience I also know there are people who like to edit tabular data in spreadsheet. The workflow being that you export a bunch of data using a query, modify it in a spreadsheet, then upload the same spreadsheet to have the values updated on the backend.
ODF Toolkit is licensed under the Apache license, requires Java 5 and available as a jar. Building the jar itself appears to require netbeans.
