[Geoserver-devel] [jira] Created: (GEOS-2646) ReverseProxyFilter does not take into account the possibility that geoserver will be the root applications
                 Key: GEOS-2646
                 URL: http://jira.codehaus.org/browse/GEOS-2646
             Project: GeoServer
          Issue Type: Bug
          Components: Struts
    Affects Versions: 1.6.5
         Environment: CentOS, TomCat5
            Reporter: Chris Jensen
            Assignee: Andrea Aime
ReverseProxyFilter.class appears to do a search and replace on the geoserver output, that does not take into account that someone may want to run the geoserver in a root container, instead of the default geoserver/ container. When it compares the base url (/) to the / in an ending html tag (</a> for instance), it thinks it needs to replace it. </a> becomes </geoserver/a> and breaks output.
