Message:
A new issue has been created in JIRA.
View the issue:
http://jira.codehaus.org/browse/GEOS-267
Here is an overview of the issue:
Key: GEOS-267
Summary: Create a 'view logs' screen in the web admin tool.
Type: Improvement
Status: Open
Priority: Critical
Original Estimate: Unknown
Time Spent: Unknown
Remaining: Unknown
Project: GeoServer
Components:
Struts
Fix Fors:
1.3.0
Assignee: Chris Holmes
Reporter: Chris Holmes
Created: Tue, 28 Dec 2004 10:47 AM
Updated: Tue, 28 Dec 2004 10:47 AM
Description:
This is basically the last piece we need to be able to completely diagnose geoserver errors over the web. The verbose exceptions was a nice start, but it would be even more helpful if you could go to a page on the web admin tool and view the logs. Probably should put it in the admin section. Not quite sure how to implement, as there is not standard logging location. Which would be a good start - probably should combine this with the GEOSERVER_HOME stuff, one of the sub directories would be 'logs'. This may not work so well with the war installations, but we may be able to have even more control of the java logger, create a console logger that outputs to geoserver_home/logs.
JIRA INFORMATION:
If you want more information on JIRA, or have a bug to report see:
