Allow for certain invalid characters (such as a period) in the created shapefile name
Key: GEOS-2692
URL: http://jira.codehaus.org/browse/GEOS-2692
Project: GeoServer
Issue Type: Improvement
Components: WFS
Affects Versions: 1.7.x
Reporter: Aleda Freeman
Assignee: Andrea Aime
Andrea's comment:
"... shapefile output format has been reworked in the 1.7.x series to deal with request with multiple feature types, the changes results in a problem when the name of the created shapefile contains invalid characters: the datastore fixes the name and as a result the generated shapefile does not have the same name as the original feature type, resulting in the exception you're seeing."
Error results otherwise:
05 Mar 13:27:22 WARN [wfs.respons] - Error while writing featuretype 'GISDATA.TOWNS_POLY' to shapefile.
java.io.IOException: No such type : GISDATA.TOWNS_POLY
at org.geotools.data.shapefile.ShapefileDataStore.typeCheck(ShapefileDataStore.java:545)
at org.geotools.data.shapefile.ShapefileDataStore.getSchema(ShapefileDataStore.java:599)
at org.geotools.data.shapefile.ShapefileDataStore.getFeatureSource(ShapefileDataStore.java:946)
at org.geoserver.wfs.response.ShapeZipOutputFormat.writeCollectionToShapefile(ShapeZipOutputFormat.java:195)
at org.geoserver.wfs.response.ShapeZipOutputFormat.write(ShapeZipOutputFormat.java:156)
at org.geoserver.wfs.WFSGetFeatureOutputFormat.write(WFSGetFeatureOutputFormat.java:137)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:711)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:215)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:200)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:283)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:773)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:703)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:895)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
at java.lang.Thread.run(Thread.java:595)
