refreshVisibility in KML reflector output
Key: GEOS-2702
URL: http://jira.codehaus.org/browse/GEOS-2702
Project: GeoServer
Issue Type: Improvement
Components: Google Earth KML Output
Affects Versions: 1.7.3
Reporter: David Winslow
Assignee: David Winslow
Allow users to request KML with timer-based autorefreshing enabled. This involves setting <refreshMode>onInterval</refreshMode> in the KML. It would be good to allow the user to specify the refresh rate as well.
