Making logging configuration its own object
Key: GEOS-2727
URL: http://jira.codehaus.org/browse/GEOS-2727
Project: GeoServer
Issue Type: Task
Components: Configuration
Reporter: Justin Deoliveira
Assignee: Justin Deoliveira
Logging configuration is somewhat tricky, because we want to read it before the configuration is read, but at the same time want to define its verbosity in the configuration. Making logging configuration its own object will help and remove the burden of having to read the configuration twice on server startup.
