Port tests to new configuration and catalog apis
Key: GEOS-2729
URL: http://jira.codehaus.org/browse/GEOS-2729
Project: GeoServer
Issue Type: Task
Reporter: Justin Deoliveira
Assignee: Justin Deoliveira
The test setup assumes the old data directory structure is used. This only affects tests which need to add types dynamically or copy files into the feature type / coverage configuration directories.
