Check there are no dependent objects before removing a catalog item
Key: GEOS-2731
URL: http://jira.codehaus.org/browse/GEOS-2731
Project: GeoServer
Issue Type: Bug
Reporter: Andrea Aime
Assignee: Justin Deoliveira
Fix For: 2.0.x
Calling catalog.remove(StoreInfo) removes the store from the catalog, but does not remove any of the dependent objects.
Either this should trigger an exception, or drop all of the dependent objects.
Client wise, it would be nice to get a list of the dependent objects.
That list must be generated somehow anyways to perform the check, and woud help the client code to perform a deep delete and to present the user what is actually going to be deleted.
