[Geoserver-devel] [jira] Created: (GEOS-2744) Raster Issue - no-data pixels in full tiles should be 0xFF instead of 0x00
                 Key: GEOS-2744
                 URL: http://jira.codehaus.org/browse/GEOS-2744
             Project: GeoServer
          Issue Type: Bug
          Components: ArcSDE
    Affects Versions: 1.7.3
            Reporter: Aleda Freeman
            Assignee: Andrea Aime
            Priority: Minor
         Attachments: impervious_surface.jpg
http://maps.massgis.state.ma.us/geoserver/wms?bbox=33000.49999999968,774000.4999999831,332999.50000000186,961999.49999999&styles=IMG_IMPERVIOUSSURFACE::Default&Format=application/openlayers&request=GetMap&version=1.1.1&layers=massgis:GISDATA.IMG_IMPERVIOUSSURFACE&width=800&height=470&srs=EPSG:26986
Two big block of purple (in the ocean and CT) should be "white".
Screenshot also attached.
Previously Gabriel had mentioned:
"you will note the no-data pixels in full tiles are purple, which is a mistake of setting the sample values for empty tiles to 0xFF instead of 0x00. It'll be fixed as soon as I upload an updated version of the work."
So wherever this needs to be changed I guess still does?
