SDE Raster issue - Error fetching colormap data
Key: GEOS-2745
URL: http://jira.codehaus.org/browse/GEOS-2745
Project: GeoServer
Issue Type: Bug
Components: ArcSDE
Affects Versions: 1.7.3
Reporter: Aleda Freeman
Assignee: Andrea Aime
Although Gabriel got SDE raster layers with colormaps to work on arcy, when I put 1.7.3 on maps.massgis.state.ma.us I have trouble loading any SDE raster layer with a colormap. What's different between our two setups? Same Oracle/SDE and same datalayer in this case.
12 Mar 12:08:56 ERROR [arcsde.gce] - Unable to creata ArcSDERasterReader for sde:/massgis:massgis@anonymised.com:5151/gis#GISDATA.IMG_USGSQUADM.
org.geotools.arcsde.ArcSdeException: Error fetching colormap data for column 80[SDE error -37][Error desc=DBMS TABLE DOES NOT EXIST.][Extended desc=
at org.geotools.arcsde.gce.ArcSDERasterFormat.loadColorMaps(ArcSDERasterFormat.java:726)
at org.geotools.arcsde.gce.ArcSDERasterFormat.gatherCoverageMetadata(ArcSDERasterFormat.java:480)
at org.geotools.arcsde.gce.ArcSDERasterFormat.getRasterInfo(ArcSDERasterFormat.java:187)
at org.geotools.arcsde.gce.ArcSDERasterFormat.getReader(ArcSDERasterFormat.java:160)
at org.geotools.arcsde.gce.ArcSDERasterFormat.getReader(ArcSDERasterFormat.java:87)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:470)
at org.vfny.geoserver.global.CoverageStoreInfo.getReader(CoverageStoreInfo.java:339)
at org.vfny.geoserver.action.data.DataCoveragesNewAction.newCoverageConfig(DataCoveragesNewAction.java:95)
at org.vfny.geoserver.action.data.DataCoveragesNewAction.execute(DataCoveragesNewAction.java:81)
at org.vfny.geoserver.action.ConfigAction.execute(ConfigAction.java:101)
at org.apache.struts.action.RequestProcessor.processActionPerform(RequestProcessor.java:431)
at org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:236)
at org.apache.struts.action.ActionServlet.process(ActionServlet.java:1196)
at org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:432)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.rememberme.RememberMeProcessingFilter.doFilter(RememberMeProcessingFilter.java:142)
at org.acegisecurity.wrapper.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:81)
at org.acegisecurity.ui.AbstractProcessingFilter.doFilter(AbstractProcessingFilter.java:217)
at org.acegisecurity.ui.logout.LogoutFilter.doFilter(LogoutFilter.java:106)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:213)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:174)
at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:200)
at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:283)
at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:773)
at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:703)
at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:895)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:689)
at java.lang.Thread.run(Thread.java:595)
Caused by: com.esri.sde.sdk.client.SeException:
at com.esri.sde.sdk.client.k.a(Unknown Source)
at com.esri.sde.sdk.client.SeQuery.prepareQuery(Unknown Source)
at org.geotools.arcsde.gce.ArcSDERasterFormat.loadColorMaps(ArcSDERasterFormat.java:705)
... 64 more
12 Mar 12:08:56 WARN [action.RequestProcessor] - Unhandled Exception thrown: class java.lang.RuntimeException
12 Mar 12:08:56 ERROR [[/geoserver].[action]] - Servlet.service() for servlet action threw exception
ArcSDE Error Number : -37
Error Description : DBMS TABLE DOES NOT EXIST.
Extended Error Description :
