SDE Raster issue - Some layers not drawing properly at different zoom levels
Key: GEOS-2746
URL: http://jira.codehaus.org/browse/GEOS-2746
Project: GeoServer
Issue Type: Bug
Components: ArcSDE
Affects Versions: 1.7.3
Reporter: Aleda Freeman
Assignee: Andrea Aime
Attachments: img_coq2001.jpg, img_coq2001_zoomin.jpg
Here's an example - the initial view of the datalayer has the bottom right cut off.
(I assume the black will become white once http://jira.codehaus.org/browse/GEOS-2744 is done?)
This is also seen with IMG_USGSQUADM on arcy.
Then, if we zoom in one "level" on the OpenLayers toolbar, some bits disappear. (see screenshot img_coq2001_zoomin.jpg)
For the arcy IMG_USGSQUADM example, the lower right (for example, Nantucket) does draw, but only at more zoomed in scales.
