[Geoserver-devel] [jira] Created: (GEOS-2757) GeoServer 1.7.3 bundled GeoWebCache can't find geowebcache.xml
                 Key: GEOS-2757
                 URL: http://jira.codehaus.org/browse/GEOS-2757
             Project: GeoServer
          Issue Type: Bug
          Components: GWC
    Affects Versions: 1.7.3
         Environment: Tested on Windows XP Pro SP2, jdk1.6.0_06, Tomcat 6.0.18
            Reporter: Tobin Bradley
            Assignee: Andrea Aime
GeoWebCache bundled with GeoServer 1.7.3 doesn't recognize geowebcache.xml in geoserver_data_dir/gwc. Log shows:
2009-03-13 13:13:29,578 ERROR [util.XMLConfiguration] - Failed to find geowebcache.xml
2009-03-13 13:13:29,578 ERROR [layer.TileLayerDispatcher] - Unable to determine configuration directory.
Putting geowebcache.xml in geoserver/WEB-INF/classes causes the file to be read and makes the data available, but GWC doesn't utilize the cachePrefix tag in the XML file and writes the tiles to the default location instead unless GEOWEBCACHE_CACHE_DIR is set in web.xml.
Arne confirmed issue on the mailing list. Rolling back to 1.7.1 or 1.7.2 fixes the problem.
Thanks!
