FeatureType folder does not get deleted if it contains schema.xml and/or schema.xsd
Key: GEOS-2770
URL: http://jira.codehaus.org/browse/GEOS-2770
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.7.3
Reporter: Andrea Aime
Assignee: Justin Deoliveira
Fix For: 1.7.4
Say you have a ft configured with a custom schema.xml. Then you remove it, and add it back again (trying to start from a clean slate).
Remove apply/save does not remove the ft directory which still contains the schema files, and they seem to interact with the creation of a new feature type (resulting empty attribute listing or something like that, still haven't completely found out what's going on, apparently I have more than one bug interacting with each other).
