[Geoserver-devel] [jira] Created: (GEOS-2778) new directory datastore creates backup feature types instead of feature types
                 Key: GEOS-2778
                 URL: http://jira.codehaus.org/browse/GEOS-2778
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
    Affects Versions: 1.7.3
         Environment: Linux webmapping.ems.psu.edu 2.6.9-78.0.17.EL #1 Thu Mar 5 04:41:13 EST 2009 i686 i686 i386 GNU/Linux
            Reporter: Ian Turton
            Assignee: Andrea Aime
            Priority: Minor
When you generate featuretypes using the new spatial data directory you end up with a bunch of featuretype directories that end .bak and no normal featuretype directories. There is thus no place to put your templates for getFeatureInfo operations. The fix is simply to copy the backup to the normal name (and the same for info.xml.bak inside it).
