[Geoserver-devel] [jira] Created: (GEOS-2788) Intermittent build failure in GetMapTest
                 Key: GEOS-2788
                 URL: http://jira.codehaus.org/browse/GEOS-2788
             Project: GeoServer
          Issue Type: Bug
          Components: WMS
            Reporter: Ben Caradoc-Davies
            Assignee: Andrea Aime
GetMapTest sometimes fails: "Too many open files Possible file permission problem."
Running org.vfny.geoserver.wms.responses.map.png.GetMapTest
27/03/2009 04:11:06 org.geoserver.test.GeoServerAbstractTestSupport runTest
WARNING: Skipping class org.vfny.geoserver.wms.responses.map.kml.KMLLegendTransformerTest.testKMLLegendTransformer since test data is not available
DecribeFT URL for topp:states: http://demo.opengeo.org/geoserver/wfs?VERSION=1.1.0&TYPENAME=topp%3Astates&NAMESPACE=xmlns(topp%3Dhttp%3A%2F%2Fwww.openplans.org%2Ftopp)&REQUEST=DescribeFeatureType&SERVICE=WFS&=&
Supported filter: [[ the_geom bbox POLYGON ((-90.17578125 -180.3515625, -90.17578125 180.3515625, 90.17578125 180.3515625, 90.17578125 -180.3515625, -90.17578125 -180.3515625)) ] AND [[ PERSONS BETWEEN 2000000 AND 4000000 ] OR [ PERSONS BETWEEN 2000000 AND 4000000 ] OR [ PERSONS BETWEEN 2000000 AND 4000000 ] OR [ PERSONS BETWEEN 2000000 AND 4000000 ]]]
Unupported filter: Filter.INCLUDE
27 Mar 04:11:11 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: Could not connect to remote OWS
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.connectRemoteWFS(GetMapKvpRequestReader.java:1123)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.addRemoteLayersFromUserLayer(GetMapKvpRequestReader.java:630)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.processStandaloneSld(GetMapKvpRequestReader.java:548)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.processSld(GetMapKvpRequestReader.java:429)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:257)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:70)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1091)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:430)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:208)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1040)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1007)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:454)
  at org.vfny.geoserver.wms.responses.map.png.GetMapTest.testRemoteOWSUserStyleGet(GetMapTest.java:143)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: org.geotools.data.DataSourceException: Exception Report java.io.IOException: Possible file
      permission problem. Root cause: java.io.IOException:
      Root cause: java.io.IOException: Too many open files Exception Code:NoApplicableCode Locator:
  at org.geotools.data.wfs.WFSDataStoreFactory.parseCapabilities(WFSDataStoreFactory.java:419)
  at org.geotools.data.wfs.WFSDataStoreFactory.createDataStore(WFSDataStoreFactory.java:348)
  at org.geoserver.wms.kvp.GetMapKvpRequestReader.connectRemoteWFS(GetMapKvpRequestReader.java:1121)
  ... 51 more
Tests run: 6, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 4.162 sec <<< FAILURE!
