Can't reload the stored configuration after restart on trunk
Key: GEOS-2796
URL: http://jira.codehaus.org/browse/GEOS-2796
Project: GeoServer
Issue Type: Bug
Reporter: Andrea Aime
Assignee: Justin Deoliveira
Fix For: 2.0.x
Steps:
- add a postgis datastore
- stop geoserver
- restart
The result is:
{code}
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
27 mar 18:32:35 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: C:\progetti\geoserver\src\trunk\data\release
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'burg'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'capitals'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'cite_lakes'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'concat'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'dem'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'flags'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'giant_polygon'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'grass'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'green'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'line'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'poi'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'point'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'polygon'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'poly_landmarks'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'pophatch'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'population'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'rain'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'raster'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'restricted'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'simple_roads'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'simple_streams'
27 mar 18:32:35 INFO [org.geoserver] - Loaded style 'tiger_roads'
27 mar 18:32:35 INFO [org.geoserver] - Loaded workspace 'cite'
27 mar 18:32:35 INFO [org.geoserver] - Loaded workspace 'it.geosolutions'
27 mar 18:32:35 INFO [org.geoserver] - Loaded workspace 'nurc'
27 mar 18:32:35 INFO [org.geoserver] - Loaded store 'arcGridSample', enabled
27 mar 18:32:35 INFO [org.geoserver] - Loaded coverage store 'arcGridSample'
27 mar 18:32:36 WARN [referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS["Monte Mario / Italy zone 1", GEOGCS["Monte Mario", DATUM["Monte Mario", SPHEROID["International 1924", 6378388.0, 297.0, AUTHORITY["EPSG","7022"]], TOWGS84[-104.1,-49.1,-9.9,0.971,-2.917,0.714,-11.68], AUTHORITY["EPSG","6265"]], PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295], AXIS["Geodetic longitude", EAST], AXIS["Geodetic latitude", NORTH], AUTHORITY["EPSG","4265"]], PROJECTION["Transverse Mercator", AUTHORITY["EPSG","9807"]], PARAMETER["central_meridian", 9.0], PARAMETER["latitude_of_origin", 0.0], PARAMETER["scale_factor", 0.9996], PARAMETER["false_easting", 1500000.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["Easting", EAST], AXIS["Northing", NORTH], AUTHORITY["EPSG","3003"]]
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984", SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0], UNIT["degree", 0.017453292519943295]], PROJECTION["Mercator_1SP_Google"], PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0], PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0], PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y", NORTH], AUTHORITY["EPSG","54004"]]
27 mar 18:32:36 INFO [org.geoserver] - Loaded coverage 'Arc_Sample', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded coverage 'arcGridSample'
27 mar 18:32:36 INFO [org.geoserver] - Loaded layer 'Arc_Sample'
27 mar 18:32:36 INFO [org.geoserver] - Loaded store 'img_sample2', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded coverage store 'img_sample2'
27 mar 18:32:36 INFO [org.geoserver] - Loaded coverage 'Pk50095', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded coverage 'img_sample2'
27 mar 18:32:36 INFO [org.geoserver] - Loaded layer 'Pk50095'
27 mar 18:32:36 INFO [org.geoserver] - Loaded store 'mosaic', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded coverage store 'mosaic'
27 mar 18:32:36 INFO [org.geoserver] - Loaded coverage 'mosaic', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded layer 'mosaic'
27 mar 18:32:36 INFO [org.geoserver] - Loaded store 'worldImageSample', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded coverage store 'worldImageSample'
27 mar 18:32:36 INFO [org.geoserver] - Loaded coverage 'Img_Sample', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded coverage 'worldImageSample'
27 mar 18:32:36 INFO [org.geoserver] - Loaded layer 'Img_Sample'
27 mar 18:32:36 INFO [org.geoserver] - Loaded workspace 'sde'
27 mar 18:32:36 INFO [org.geoserver] - Loaded workspace 'sf'
27 mar 18:32:36 INFO [org.geoserver] - Loaded store 'sf', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded data store 'sf'
27 mar 18:32:36 INFO [org.geoserver] - Loaded feature type 'archsites', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded feature type 'sf'
27 mar 18:32:36 INFO [org.geoserver] - Loaded layer 'archsites'
27 mar 18:32:36 INFO [org.geoserver] - Loaded feature type 'bugsites', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded layer 'bugsites'
27 mar 18:32:36 INFO [org.geoserver] - Loaded feature type 'restricted', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded layer 'restricted'
27 mar 18:32:36 INFO [org.geoserver] - Loaded feature type 'roads', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded layer 'roads'
27 mar 18:32:36 INFO [org.geoserver] - Loaded feature type 'streams', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded layer 'streams'
27 mar 18:32:36 INFO [org.geoserver] - Loaded store 'sfdem', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded coverage store 'sfdem'
27 mar 18:32:36 INFO [org.geoserver] - Loaded coverage 'sfdem', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded layer 'sfdem'
27 mar 18:32:36 INFO [org.geoserver] - Loaded workspace 'tiger'
27 mar 18:32:36 INFO [org.geoserver] - Loaded store 'nyc', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded data store 'nyc'
27 mar 18:32:36 INFO [org.geoserver] - Loaded feature type 'giant_polygon', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded feature type 'nyc'
27 mar 18:32:36 INFO [org.geoserver] - Loaded layer 'giant_polygon'
27 mar 18:32:36 INFO [org.geoserver] - Loaded feature type 'poi', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded layer 'poi'
27 mar 18:32:36 INFO [org.geoserver] - Loaded feature type 'poly_landmarks', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded layer 'poly_landmarks'
27 mar 18:32:36 INFO [org.geoserver] - Loaded feature type 'tiger_roads', enabled
27 mar 18:32:36 INFO [org.geoserver] - Loaded layer 'tiger_roads'
27 mar 18:32:36 INFO [org.geoserver] - Loaded workspace 'topp'
27 mar 18:32:36 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name 'geoServerLoader': java.lang.NullPointerException
27 mar 18:32:36 ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [file:/C:/progetti/geoserver/src/trunk/src/main/target/classes/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: com.thoughtworks.xstream.converters.ConversionException: : expected = after attribute name (position: TEXT seen ...</Wicket__Data__Source__Name>\n <validate connections>... @13:27) : : expected = after attribute name (position: TEXT seen ...</Wicket__Data__Source__Name>\n <validate connections>... @13:27)
---- Debugging information ----
message : : expected = after attribute name (position: TEXT seen ...</Wicket__Data__Source__Name>\n <validate connections>... @13:27)
cause-exception : com.thoughtworks.xstream.io.StreamException
cause-message : : expected = after attribute name (position: TEXT seen ...</Wicket__Data__Source__Name>\n <validate connections>... @13:27)
class : org.geoserver.catalog.impl.DataStoreInfoImpl
required-type : java.util.HashMap
line number : 13
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:480)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
at java.security.AccessController.doPrivileged(Native Method)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:255)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:199)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:45)
at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:540)
at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1220)
at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:510)
at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448)
at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:39)
at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:130)
at org.mortbay.jetty.Server.doStart(Server.java:222)
at org.geoserver.web.Start.main(Start.java:57)
Caused by: java.lang.RuntimeException: com.thoughtworks.xstream.converters.ConversionException: : expected = after attribute name (position: TEXT seen ...</Wicket__Data__Source__Name>\n <validate connections>... @13:27) : : expected = after attribute name (position: TEXT seen ...</Wicket__Data__Source__Name>\n <validate connections>... @13:27)
line number : 13
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:128)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
... 24 more
Caused by: com.thoughtworks.xstream.converters.ConversionException: : expected = after attribute name (position: TEXT seen ...</Wicket__Data__Source__Name>\n <validate connections>... @13:27) : : expected = after attribute name (position: TEXT seen ...</Wicket__Data__Source__Name>\n <validate connections>... @13:27)
line number : 13
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:89)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:76)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.unmarshallField(AbstractReflectionConverter.java:246)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.doUnmarshal(AbstractReflectionConverter.java:218)
at org.geoserver.config.util.XStreamPersister$StoreInfoConverter.doUnmarshal(XStreamPersister.java:991)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.unmarshal(AbstractReflectionConverter.java:162)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:82)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:60)
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:137)
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:33)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:923)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:909)
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:861)
at org.geoserver.config.util.XStreamPersister.load(XStreamPersister.java:400)
at org.geoserver.config.GeoServerLoader.depersist(GeoServerLoader.java:657)
at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:485)
at org.geoserver.config.GeoServerLoader.loadCatalog(GeoServerLoader.java:154)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:125)
... 27 more
Caused by: com.thoughtworks.xstream.io.StreamException: : expected = after attribute name (position: TEXT seen ...</Wicket__Data__Source__Name>\n <validate connections>... @13:27)
at com.thoughtworks.xstream.io.xml.XppReader.pullNextEvent(XppReader.java:78)
at com.thoughtworks.xstream.io.xml.AbstractPullReader.readRealEvent(AbstractPullReader.java:137)
at com.thoughtworks.xstream.io.xml.AbstractPullReader.readEvent(AbstractPullReader.java:124)
at com.thoughtworks.xstream.io.xml.AbstractPullReader.hasMoreChildren(AbstractPullReader.java:78)
at org.geoserver.config.util.XStreamPersister$BreifMapConverter.populateMap(XStreamPersister.java:494)
at com.thoughtworks.xstream.converters.collections.MapConverter.unmarshal(MapConverter.java:66)
... 45 more
Caused by: org.xmlpull.v1.XmlPullParserException: expected = after attribute name (position: TEXT seen ...</Wicket__Data__Source__Name>\n <validate connections>... @13:27)
at org.xmlpull.mxp1.MXParser.parseAttribute(MXParser.java:2004)
at org.xmlpull.mxp1.MXParser.parseStartTag(MXParser.java:1799)
at org.xmlpull.mxp1.MXParser.nextImpl(MXParser.java:1127)
at org.xmlpull.mxp1.MXParser.next(MXParser.java:1093)
at com.thoughtworks.xstream.io.xml.XppReader.pullNextEvent(XppReader.java:63)
... 51 more
27 mar 18:32:36 ERROR [mortbay.log] - Failed startup of context org.mortbay.jetty.webapp.WebAppContext@anonymised.com{/geoserver,src/main/webapp}
line number : 13
line number : 13
... 24 more
line number : 13
... 27 more
... 45 more
... 51 more
27 mar 18:32:36 WARN [mortbay.log] - Nested in org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rawCatalog' defined in URL [file:/C:/progetti/geoserver/src/trunk/src/main/target/classes/applicationContext.xml]: Initialization of bean failed; nested exception is java.lang.RuntimeException: com.thoughtworks.xstream.converters.ConversionException: : expected = after attribute name (position: TEXT seen ...</Wicket__Data__Source__Name>\n <validate connections>... @13:27) : : expected = after attribute name (position: TEXT seen ...</Wicket__Data__Source__Name>\n <validate connections>... @13:27)
line number : 13
{code}
Mind the rogue "Wicket__Data__Source__Name" attribute is a hack done in the store editor page to stick the store name and description in the same format as the datastore parameters (by adding those two in the param map). The hack is very ugly and should be fixed, not sure it has anyting to do with this issue thought.
