Rendering issues caused by a poor quality shapefile
Key: GEOS-2807
URL: http://jira.codehaus.org/browse/GEOS-2807
Project: GeoServer
Issue Type: Bug
Affects Versions: 1.7.3
Environment: Issue has been replicated both on Linux(Ubuntu) and Windows systems. Both where using Sun Java.
Reporter: Ivan Willig
Assignee: Andrea Aime
Priority: Blocker
Attachments: alachua.zip
It looks like GeoServer is having a hard time rendering a shapefile that I believe has invalid geometries. Less than half of the lines are being rendered at this point. Normally I would just fix the shapefile, but in this case that is not possible. Attached below is the troublesome shapefile. This issue can be fixed by running ogr2ogr to clean the shapefile.
