[Geoserver-devel] [jira] Created: (GEOS-2811) ecw only in wgs84
ecw only in wgs84
                 Key: GEOS-2811
                 URL: http://jira.codehaus.org/browse/GEOS-2811
             Project: GeoServer
          Issue Type: Bug
          Components: WCS
    Affects Versions: 1.7.3
         Environment: Windows
            Reporter: Thomas Stegemann
            Assignee: Andrea Aime
            Priority: Minor
I have tested the support for ECW and it seems the GeoServer does not support ECW-files in proj/date other than WGS84 configured through the UI. Funny thing, the extend is correctly received from the file (in meters) but WGS84 was automatically choosen so the preview of the coverage will show up (bbox in meters got from the extent, srid = epsg:4326 for wgs84?, should be a local one) but if you call the image through wms interface (using the correct format of bbox in degree instead of meters for epsg:4326) nothing is shown.
A possible workaround is to have all the images in wgs84 instead of a local projection... but this seems to be not the best solution at all.
I didn't used any world-files / ers files (just ecw-header information).
     [ http://jira.codehaus.org/browse/GEOS-2811?page=com.atlassian.jira.plugin.system.issuetabpanels:all-tabpanel ]
Simone Giannecchini reopened GEOS-2811:
      Assignee: Daniele Romagnoli (was: Simone Giannecchini)
Reopening and assigning to daniele
ecw only in wgs84
                Key: GEOS-2811
            Project: GeoServer
         Issue Type: Bug
         Components: WCS
           Priority: Minor
        Attachments: Canada_2000_Mosaic_25.prj, Canada_2000_Mosaic_25_epsg42304.prj, Canada_2000_Mosaic_25_fails.prj
