[Geoserver-devel] [jira] Created: (GEOS-2814) Possible Memory Leak
                 Key: GEOS-2814
                 URL: http://jira.codehaus.org/browse/GEOS-2814
             Project: GeoServer
          Issue Type: Bug
          Components: PostGIS, WMS
    Affects Versions: 1.7.3
         Environment: Debian Etch, PosgreSQL 8.1, PostGIS, Java 1.5.0
            Reporter: Andrew Ayre
            Assignee: Andrea Aime
         Attachments: data.zip
Database contains a table called 'pima'. This contains six polygons from the TIGER dataset, which overlays southern Arizona.
index.html shows OpenLayers with an OSM base map and the WMS overlay from Geoserver.
Initially this works but as the map is browsed, zoomed in and out, etc. the memory usage by java increases until it runs out of heap space.
