[Geoserver-devel] [jira] Created: (GEOS-2822) Geoserver fails reprojecting 2238 and 900913 in BBOX spatial queries
                 Key: GEOS-2822
                 URL: http://jira.codehaus.org/browse/GEOS-2822
             Project: GeoServer
          Issue Type: Bug
          Components: WFS
    Affects Versions: 1.7.3
         Environment: Windows server 2003, Sun Java 1.6, http://www.nikos.alachua.fl.us:8080/geoserver, shapefile data store
            Reporter: Tim Coulter
            Assignee: Andrea Aime
When making a BBOX request on data whose native projection is ESPG:2238 (the projection on the BBOX request is EPSG:900913) the request fails with the error:
<ows:ExceptionText>java.lang.RuntimeException: Could not
      decode srs &amp;apos;EPSG:900913&amp;apos; Could not
      decode srs &amp;apos;EPSG:900913&amp;apos; null</ows:ExceptionText>
The request:
<?xml version="1.0"?>
<wfs:GetFeature xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; service="WFS" version="1.1.0" maxFeatures="501" xsi:schemaLocation="http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd&quot;&gt;
  <wfs:Query xmlns:alachua="http://www.nikos.alachua.fl.us" typeName="alachua:urban_cluster" srsName="EPSG:900913">
    <ogc:Filter xmlns:ogc="http://www.opengis.net/ogc&quot;&gt;
      <ogc:BBOX>
        <ogc:PropertyName>the_geom</ogc:PropertyName>
        <gml:Envelope xmlns:gml="http://www.opengis.net/gml&quot; srsName="EPSG:900913">
          <gml:lowerCorner>-9186737.1172306 3446893.8079555</gml:lowerCorner>
          <gml:upperCorner>-9145613.9960205 3470589.2867197</gml:upperCorner>
        </gml:Envelope>
      </ogc:BBOX>
    </ogc:Filter>
  </wfs:Query>
</wfs:GetFeature>
Reproduce by making the above request to http://www.nikos.alachua.fl.us:8080/geoserver
Note: When we first added the alachua:urban_cluster layer to Geoserver, Geoserver was unable to detect that the layer was EPSG:2238 even though EPSG:2238 was installed. With the default configuration values set by Geoserver after the first install, we received the same error as the above, except that it reported "Could not decode EPSG:2238" (as opposed to EPSG:900913). After manually setting the projection to 2238, we received the error shown above. EPSG:900913 is installed.
