[Geoserver-devel] [jira] Created: (GEOS-2829) Get BBox fails on PostGIS data source
                 Key: GEOS-2829
                 URL: http://jira.codehaus.org/browse/GEOS-2829
             Project: GeoServer
          Issue Type: Bug
          Components: Configuration
    Affects Versions: 1.7.3
         Environment: PostGIS 1.4, Postgres 8.3.6, Ubuntu 8.10 32bit
            Reporter: Brian Hamlin
            Assignee: Andrea Aime
         Attachments: smZip.tgz
using a PostGIS data source, several tables add fine using the FeatureType editor window, but several do not.
no sign of 3d data, yet BBox fails with envelope(box3d_extent) does not exist.
workaround is to create a new table with st_force_2d(), which apparently does fix it..
