[Geoserver-devel] [jira] Created: (GEOS-2837) Port the SRS handilng portion of the GeoServer wiki to sphinx
                 Key: GEOS-2837
                 URL: http://jira.codehaus.org/browse/GEOS-2837
             Project: GeoServer
          Issue Type: Task
    Affects Versions: 1.7.3
            Reporter: Andrea Aime
            Assignee: Mike Pumphrey
             Fix For: 1.7.4
Proper SRS handling is crucial to get accurate reprojections. At least those two pages need porting into the new guide:
http://geoserver.org/display/GEOSDOC/Configuring+your+data+Coordinate+Reference+System
http://geoserver.org/display/GEOSDOC/Custom+projection+definition+in+Geoserver+1.5.0+(onwards)
(well, I could only check the contents of the latter, the first I could not see because Confluence died on me but the title looks promising).
Also, the epsg_overrides.properties file needs documentation.
