Populate DataStoreInfo type property
Key: GEOS-2844
URL: http://jira.codehaus.org/browse/GEOS-2844
Project: GeoServer
Issue Type: Bug
Components: Configuration
Reporter: Andrea Aime
Assignee: Justin Deoliveira
Fix For: 2.0.x
Populate the type property on data dir conversion, and when first building new store info objects (in the CatalogBuilder? the code must be shared by the UI and the REST configuration). Alternatively, have the property be populated the first time it's looked up (tricky, that does not trigger a save event so we may end up doing so over and over).
