[Geoserver-devel] [jira] Created: (GEOS-2847) Unable to overwrite shapefiles using rest configuration tool
                 Key: GEOS-2847
                 URL: http://jira.codehaus.org/browse/GEOS-2847
             Project: GeoServer
          Issue Type: Bug
          Components: REST
    Affects Versions: 1.7.3
            Reporter: Darren Karstens
            Assignee: Andrea Aime
When using the rest configuration to PUT zipped shapefiles to the server it works the first time but then produces an error saying "error in opening zip file" the 2nd time you attempt to upload. The URL used is /geoserver/rest/<ws>/maps/datastores/<ds>/file.shp. I also noticed that the original .shp file in the \data_dir\data\<ds> folder had changed to .shp.zip the 2nd time I uploaded the files.
