[Geoserver-devel] [jira] Created: (GEOS-2855) CoverageStore creation failures are not handled
                 Key: GEOS-2855
                 URL: http://jira.codehaus.org/browse/GEOS-2855
             Project: GeoServer
          Issue Type: Bug
          Components: Wicket UI
    Affects Versions: 2.0-alpha1
            Reporter: Gabriel Roldán
            Assignee: Gabriel Roldán
             Fix For: 2.0-beta1
Creating a new coverage store with wrong parameter names produces a failure and an html page with a stack trace. Going back to add the coverage store with the correct parameters also fail because the coverage store was already added to the catalog with a stack trace like the following:
{code}
java.lang.IllegalArgumentException: Store '<store name>' already exists in workspace '<ws name>'
  at org.geoserver.catalog.impl.CatalogImpl.validate(CatalogImpl.java:150)
  at org.geoserver.catalog.impl.CatalogImpl.save(CatalogImpl.java:164)
  at org.geoserver.security.SecureCatalogImpl.save(SecureCatalogImpl.java:950)
  at org.geoserver.web.data.coverage.CoverageStoreConfiguration$1.onSubmit(CoverageStoreConfiguration.java:135)
  at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1351)
  at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:810)
{code}
If creating the store fails the UI should:
- present a failure message in the same "add coverage store" page
- do not add the store to the catalog at all until the creation of the store succeeds
